March 15, 2026
STM32CubeMX unable to generate STM32CubeIDE project.
  • March 15, 2026
  • 443 views
Hello, I got following problem.
STM32CubeMX is unable to properly generate .project file for STM32CubeIDE. After clicking "GENERATE CODE", MX is copying library files, generating .h and .c files, but no .project file.
Following nullpointer exception can be found in log file. I already tested different versions of JAVA - no change.
I attached error messages, MX log, and .ioc file.
Anyone managed to fix this?
2026-03-15 10:27:00,707 [ERROR] ToolchainGenerator:531 -
java.lang.reflect.InvocationTargetException: null
	at jdk.internal.reflect.DirectMethodHandleAccessor.invoke(DirectMethodHandleAccessor.java:115) ~[?:?]
	at java.lang.reflect.Method.invoke(Method.java:580) ~[?:?]
	at com.st.microxplorer.plugins.projectmanager.model.ToolchainGenerator.CallMethod(ToolchainGenerator.java:406) ~[?:?]
	at com.st.microxplorer.plugins.projectmanager.model.ToolchainGenerator.generate(ToolchainGenerator.java:506) ~[?:?]
	at com.st.microxplorer.plugins.projectmanager.engine.ProjectBuilder.createToolChainFolders(ProjectBuilder.java:5583) ~[?:?]
	at com.st.microxplorer.plugins.projectmanager.engine.ProjectBuilder.createProject(ProjectBuilder.java:987) ~[?:?]
	at com.st.microxplorer.plugins.projectmanager.engine.GenerateProjectThread.run(GenerateProjectThread.java:61) ~[?:?]
Caused by: java.lang.NullPointerException: Cannot invoke "Object.hashCode()" because "key" is null
	at java.util.Hashtable.put(Hashtable.java:481) ~[?:?]
	at sun.rmi.registry.RegistryImpl.rebind(RegistryImpl.java:287) ~[?:?]
	at com.st.stm32cube.ide.common.services.mx.jar.core.mx.rmi.MailBox.connectNewMailBox(MailBox.java:46) ~[?:?]
	at com.st.stm32cube.ide.common.services.mx.jar.core.mx.plugin.PlugIn.setupMailBox(PlugIn.java:282) ~[?:?]
	at com.st.stm32cube.ide.common.services.mx.jar.core.mx.plugin.PlugIn.doExecute(PlugIn.java:329) ~[?:?]
	at com.st.stm32cube.ide.common.services.mx.jar.core.mx.plugin.PlugIn.doGenerate(PlugIn.java:295) ~[?:?]
	at com.st.stm32cube.ide.common.services.mx.jar.core.mx.plugin.PlugInAbstract.generate(PlugInAbstract.java:44) ~[?:?]
	at com.st.stm32cube.ide.common.services.mx.jar.core.mx.plugin.PlugInAbstract.generate(PlugInAbstract.java:32) ~[?:?]
	at jdk.internal.reflect.DirectMethodHandleAccessor.invoke(DirectMethodHandleAccessor.java:103) ~[?:?]
	... 6 more
KopytkoAuthor
March 15, 2026
PS:
MX version is 6.17.0
IDE version is: 2.1.0
Hello @Kopytko
Let me thank you for posting.
I am unable to reproduce the behavior described.
The project was generated correctly, and the compilation completed successfully without any errors.
Pavel A.
March 15, 2026
Traces of devil detected in the log. Spray the machine with holy water!
March 24, 2026
