LLEUNGAssociateForum|Forum|2 years agoJanuary 19, 2024QuestionSTEVAL-CTM015V1----Can the switched reluctance motor driver not use the built-in STM32F3 MCU?Forum|Forum|2 years agoJanuary 19, 20241 reply2132 viewsSTEVAL-CTM015V1This evaluation board is a driver for the switched reluctance motor and comes with an MCU of STM32F3. Can I use other external MCU instead of this MCU(STM32F3)? If so, how?THANK YOUsteval-ctm015v1.pdfum3174-getting-started-with-stevalctm015v1-1kw-400vdc-threephase-switched-reluctance-motor-drive-stmicroelectronics.pdf
