Turnkey gesture recognition STSW-IMG035 library port to RISC-V Chips
Is there anyway to port the libGesturesMZ.a library to RISC-V or provide source code for this? Currently only can be used with Arm Cortex chips and we want to be able to use the VL53L5 sensor with Risc-V chip the standard code to operate VL53L5 is processor agnostic, but the library to power gesture control is not. Let me know best path forward. Thanks
