February 3, 2025
Board & debugger for firmware validation on STM32L475RET6TR
  • February 3, 2025
  • 705 views
Hi All,
Thanks for advance!
Actually i have selected STM32L475RET6TR  MCU for my one of my project. I am looking for the best Evaluation/ development board for the above microcontroller part..
i found  B-L475E-IOT01A this discovery kit board...
My query, is this discovery kit  useful for firmware development/testing purpose B-L475E-IOT01A ?
or can anyone suggest the best Evaluation board for the above part.
    Hello @Ramsiri12 and welcome to the ST community.
    If your code does not need lot of exposed pins (only the Arduino connector), in this case the B-L475E-IOT01A should do the job for you specially for a IOT application. Else, if you are looking for more pins exposed that you can use on your development, you can use the NUCLEO-L476RG as recommended on the STM32L475RE - Ultra-low-power with FPU Arm Cortex-M4 MCU 80 MHz with 512 Kbytes of Flash memory, USB OTG, DFSDM - STMicroelectronics.
    Best Regards.
    STTwo-32
    Ramsiri12Author
    February 3, 2025
    Thanks for your response...
    can we use this NUCLEO-L476RG for my part STM32L475RET6TR ? for my firmware development.. because i have checked the  NUCLEO-L476RG datasheet, in that they did not mention this STM32L475RET6TR as a target ..only they mentioned the target as STM32L476...
    can you please suggest one best debugger/programmer for this STM32L475RET6TR ?
    You need to use a board that use a similar MCU and not the same one since there is not any evaluation board based on the STM32L475RET6TR.
    Best Regards.
    STTwo-32
    February 3, 2025
    As always, go to the Product Page for your chosen part, and look on the 'Tools & Software' tab:
    https://www.st.com/en/microcontrollers-microprocessors/stm32l475re.html#tools-software
    There you will find all recommended tools - including development/evaluation boards.
