sending data using I2C on Simulink
Hi there,
I'm using Nucleo-G474RE to send a bit stream over Simulink, instead of receiving 24 bits on the oscilloscope i can read only 8 bits, which are supposed to be the 8 bits in the middle that have the address of the peripheral and the status of the I2C block gives me 516 which is not on the documentation from matlab.
