September 20, 2025
RTC date is reset after power off in STM32F103C8T6
  • September 20, 2025
  • 454 views
HELLO ,In STM32F103C8T6, the RTC time is preserved after power off, but the date always resets to 01/01/2000 even if I set the current date and time.
September 20, 2025
What hardware is this? Is VBAT remain connected? When you debug, does the magic value prevent the RTC from being re-initialized?
Shirley.Ye
September 23, 2025
In the STM32F103C8T6 RTC only has a 32-bit counter (the "RTC counter"), which counts seconds. The date is calculated in software based on the counter value.
The date (year, month, day) is calculated by your code (or the HAL/StdPeriph library) from the RTC counter. Any software variables or RAM values are lost when power off unless you store them in the RTC backup registers
