smhhadima
August 12, 2015
uint16_t VS __IO uint16_t
  • August 12, 2015
  • 1492 views
Posted on August 12, 2015 at 14:20
what is the difference between ''uint16_t'' VS ''__IO uint16_t'' ?
    John F.
    August 12, 2015
    Posted on August 12, 2015 at 14:26
    Typically in one or more header files you'll find something like,
    #ifdef __cplusplus
    #define __I volatile /*!< defines 'read only' permissions */
    #else
    #define __I volatile const /*!< defines 'read only' permissions */
    #endif
    #define __O volatile /*!< defines 'write only' permissions */
    #define __IO volatile /*!< defines 'read / write' permissions */
    August 12, 2015
    Posted on August 12, 2015 at 14:43
    volatile is important for peripheral registers, they don't act like memory, and operate independently of the processor, require strict sequencing and reading every time they are used.
    Nesrine M_O
    August 12, 2015
    Posted on August 12, 2015 at 15:08
    Hi SamTheMan,
    __IO = volatile is a variable that no compiler optimization is applied.
    A variable should be declared volatile whenever its value could change unexpectedly.
    -Syrine-
    smhhadima
    smhhadimaAuthor
    August 12, 2015
    Posted on August 12, 2015 at 19:23
    thank you
