STM32F107 USB device - Non standard endpoint request notification
I am trying to implement � USB Test & Measurement Class � on STM32F107 Microcontroler Familly.
I use the lastest librarie version � STM32 USB On-The-Go Host and Device Library � V2.0.0.
To have notification on usb setup stage, I had to modified the usbd_req.c file because the event (endpoint) from the host with an non standard request was ignored !
The librarie should check if bmRequest is an USB_REQ_TYPE_STANDARD, USB_REQ_TYPE_CLASS or USB_REQ_TYPE_VENDOR type.
I don't know if it's the best method, but if you have some tips, thank you in advance for your replies.
Best regards, Thierry
#stm32f107-usb-device-usbd_req.c
